Alky control kit wiring
Old Aug 24, 2010 | 08:56 PM
MUSTANGBRKR02's Avatar
Question Alky control kit wiring
Ok I got the kit wired up but i wanted to double check to make sure that it is all correct.
I have the three main wires off the pump correct (came off of a running car) to the Dist block.
From the PAC controller I have
Red= positive 12v source
Black= ground
Green= Pin 32 on the red pcm connector (2 bar MAP)
Orange/brown= to the dual LED
From the tank
White wire= to Red LED wire and black wire to chassis ground
All of this sound correct?
