Cometic vs GM MLS
Old Sep 6, 2010 | 06:19 PM
BLAKE 01 WS6's Avatar
Default Cometic vs GM MLS
Which head gaskets are you guys running? I will be running a D1SC(8psi) with GT2-3 cam on the stock bottom end(around 500rwhp)? Are the cometics worth the extra $$ over the GM MLS? I will also be using ARP head studs.
Old Sep 6, 2010 | 07:59 PM
9sectruck's Avatar
rwhp in sig. I have heard good things about guys really pushing on stock mls gaskets, if im no mistaking some of the gm gaskets are 5 layer??
Old Sep 6, 2010 | 08:43 PM
blue00ZZleeper's Avatar
Standard GM MLS gaskets are 5 layer. You can also go with LS9 head gaskets if your using 317 heads, their 7 layer. I've ran the standard GM gaskets the whole time I've had my car and not a single problem yet.
Old Sep 7, 2010 | 11:31 AM
WARPNOVA's Avatar
3rd vote for the GM MLS gaskets. The Cometic are very hit a miss. You either swear by them or swear at them. Not much middle ground from what I have heard. I just put a set of Cometic’s on my buddies NA setup. This is the first set of Cometic's I have ever used so I guess I will see which swearing group I end up in. LOL
Old Sep 7, 2010 | 11:58 AM
smokinHawk's Avatar
go gm unless you need a special thickness, then do cometic.
Old Sep 7, 2010 | 12:35 PM
99SS-T's Avatar
Are the LS9 MLS's better then the regular ones? I never heard of that so I wanna see wince I'm about to toss the heads on. Thanks!
Old Sep 7, 2010 | 01:01 PM
WARPNOVA's Avatar
I second that, special thickness is the only reason we used cometic on my buddies build.
Old Sep 7, 2010 | 02:34 PM
Thanks guys, GM MLS it is
Old Sep 8, 2010 | 08:20 AM
Big_Bird_WS6's Avatar
to bring this back up real quick.
what gasket do you guys run on bigger than stock bore. like say a 4.125?
i heard the ls7 wont work the best witht he water lines. any imput would help.
thanks
D
Old Sep 8, 2010 | 04:20 PM
Packy's Avatar
I have been using GM MLS gaskets since '03 and they are holding up well. I only push around 8-9 psi though.
Old Sep 9, 2010 | 02:00 AM
BottleFedZ346's Avatar
Looks like it will be GM MLS for me as well.....
Old Sep 9, 2010 | 11:28 AM
99SS-T's Avatar
No info on the LS9 MLS? Just wondering if it is a better option then the reg 5 layer that everyone is using?
Old Sep 9, 2010 | 11:34 AM
Thanks guys, for what I saved on the gaskets I bought a new set of lifters.
^^^^ figureing it is made for a boosted motor. i am going to say it is better. and it came out after the 5 laye. so i dont think GM would go bawards in gaskets
Old Sep 9, 2010 | 06:44 PM
LS9 gaskets are 7 layer. Do a search. This issue just cam up not to long ago. There was also part numbers listed.
