NBM-LS1's Front Mount Build! UPDATE **9/9/2011**
#77
This is a A/C yes.
The PS gets relocated via a supplied bracket. Everything else stays put.
With the T6 Turbos you do need a BMR Turbo K-member. It allows for the 4" DP to be routed under the Steering shaft.
The radiator needs to be stood up. The Condensor needs to have some new lines made. Small price to pay for a setup that can be made to fit a Turbo all the way up to a 114mm Thumper.
#80
