Water Vapor Collection system
Old May 18, 2012 | 08:12 PM
  #81
TermnEatr's Avatar
Originally Posted by willizm
Just reading this thread now and picked up the KUP vent system for my turbo car. I might not be pushin the power levels some of you guys are, but after reading threads like "the Alchemist" started on the number 7 failures I knew I wanted to help prolong the life of my motor. Here are a couple pics of how it looks with an ls6 intake. I had the intake removed to install the fittings and line then slid it back into place. Don't mind some of the clutter, still cleaning up a few things.
Kurt if you have any suggestions on my mounting let me know. There were no instructions so I'm just shooting from the hip. Also I'm having my brother build a bracket to hold the manifold as it's sort of just free floating right now.
Velcro strip that bad boy to the intake !
Old May 19, 2012 | 11:45 AM
  #82
Reckless's Avatar
Super Moderator
You can make a simple "Z" shaped bracket and use one of the intake bolts to hold it down. The collection block is already tapped for two screws.
Old May 22, 2012 | 10:01 PM
  #83
BillyBob750's Avatar
Here's a couple pictures of my intake plumbed and Kurt's kit installed.
Old May 23, 2012 | 08:18 AM
  #84
MIGHTYMOUSE's Avatar
well i went with this
compromise between looking good / stock and working right. i figure any amount of flow from the rear is better than how i've had it for the last.. well ever.
