twin turbo 5.3.?
Old Sep 22, 2010 | 06:31 AM
Bobsmyuncle's Avatar
Default twin turbo 5.3.?
doin a 5.3 swap into a bmw, we planned on using 2- 40mm garrets. was wondering if anyone had any input as to how well these would do. we are going for INSTANT spool. Its not a track car, a street car. 5.3 is gonna be BONE STOCK. flipped manifolds, ls1 or ls6 intake, and front mount. planning on 12psi.
THANKS
EDIT: THE TURBOS ARE OFF OF A 1990 300ZX. HOW DO U THINK THESE WILL DO ON THE 5.3?
Old Sep 22, 2010 | 07:26 AM
LS1DIME's Avatar
I have a set of T04b's mounted out back and the 5.3L I had in my truck before spooled them almost seemlessly when ya got on it! I pushed the ringlands on #3 cylinder at 20 psi and had a blast doin it! It was bone stock except for upgraded injectors! I would say your setup would work great!
Old Sep 22, 2010 | 04:02 PM
what do u think we could run boost wise, and be safe? Its got about 60k. We would like to go past 500 wheel.
Stock everything except intake/injectors.
Thnks.
Old Sep 22, 2010 | 06:47 PM
novaflash2002's Avatar
a zo6 cam swap, good set of vlave springs, and a single 76mm turbo will get you your goal and then some.
Old Sep 22, 2010 | 08:59 PM
kdavis's Avatar
I think 15 psi would be safe. Just check the tune and make sure it's spot on and you have good gas
By Brett Foote | 2026-06-04 05:00:17
