Quick question - Glowing manifold, low speed
Fired the car and got it going alright. Drove it up and down the road and the manifold is flat out glow-in-the dark. Id expect this to be normal for WOT bursts and other drive-like-an-idiot conditions, but not casual drive like a gramma up and down the road. It's enough to severely heatsoak the charge pipe post-intercooler from about 8" away
What causes this? My best guess so far is excessive rich condition from untuned bigger injectors or the turbo is flat worn out
All cyls are firing properly, not sure how ridiculous the IATs are getting. Havent picked up or heard anything relating to pinging or knock so I doubt its a lean condition
Darn thing sounds like a diesel
24# are huge for it and well needed with the addition of an intercooler and the boost turned up from 7psi to 20
Power compared to LSx is dismal at best, but it's his engine. I just wanted a base to start troubleshooting it and I got it. Thanks
Wait, sounds like a diesel? That is your timing.
I did the oil pump on this engine, which required me to pull the timing belt and reinstall it. Pocket lives about 30 minutes from me, so I was trying to get the car home before dark and didn't reset ignition timing. I suppose it's worth mentioning that the car is a 1986 Fiero. I've been rebuilding the 2.0 Turbo Grand Am engine at Pocket's house. Anyway, 30 seconds out of his driveway, I turned around to look through the rear bulkhead (between the seats) at the engine. The exhaust mani was glowing bright orange. It wasn't just a low glow, it looked like this:
Anyway, it scared me enough to merit pulling over. I know the mani should be getting hot, but certainly not glowing orange at 30mph. I'll wait for the sun to come up a little bit more and go set the timing. I made it brief earlier, I didn't want any of my neighbors coming out with a 12 gauge for cranking a open downpipe turbo car at 7am Sunday morning.
I changed turbos and got a mpt70, and had no more problems.
Let your car idle, take off a piece of inlet tubing that runs from the turbo to the motor (doesn't matter which piece, ANY piece)....with car idleing, feel how much air flow you have comming from turbo.
It should be minimal,very minimal. If you have a good bit, then your turbo is too small. Mine felt almost like a hair dryer was running on a low setting. Neeedless to say, if I drove it down the road, hard driving or not, it would glow red just as what you are describing, and once it started glowing, no matter at idle or not, the exhaust gas couldn't get out, it would glow red all the time.
Just my experience
Regarding the larger injectors, there was a bit of confusion; I never installed any, the injectors are OEM. In any other application, to command more boost, we'd most likely have to up the injector size or increase the duty cycle. Gm's older line of turbo engines were never engineered to take advantage of an intercooler, and so GM circa 1990 programmed the injectors to dump raw fuel to keep charge temperatures down. One owner on the J-body forum has reported being able to cut the original duty cycle by almost half with the addition of an efficient a-a intercooler. I'm hoping to be able to trim the fuel a good amount once I get all the bugs sorted out of the system.
The engine makes more power and torque than the standard V6, is a great deal lighter, and hopefully won't be that thirsty after trimming the fuel. Although, it's been a royal PITA for Pocket and I given my limited budget and use of Volvo charge pipe couplers. xD
Makes sense, thanks for sharing! The turbo is the stock Garret T25 (not T2), I'm hoping the timing was responsible and the turbo doesn't need to be rebuilt.
Is there a way to bleed off some fuel pressure while it's running, so see if the glow goes away? (cut down on fuel psi) Adjustible fuel pressure regulator? Maybe a fuel pressure schrader valve that we can put a gauge on, release some pressure that way?
can you advance the timing to see if that helps?
Lets see what happens!
