370ci, s85, th400 build update
Old Oct 4, 2010 | 12:16 AM
LS1PUNK's Avatar
Those S85's are HUGE! I remember seeing one a couple years back in notch back, I was amazed that something like that could fit in a engine bay with a motor at the same time.
Old Oct 4, 2010 | 07:13 PM
trans2000am's Avatar
couple more pics from today, was able to mount the passenger side upper an lower control arms an strange da coilovers, still have to tighten everything down.
also mocked up the intercooler an got the downpipe mounted its a whole lot of exhaust lol
Attached Thumbnails 370ci, s85, th400 build update-pa040053.jpg   370ci, s85, th400 build update-pa040052.jpg   370ci, s85, th400 build update-pa040051.jpg   370ci, s85, th400 build update-pa040050.jpg   370ci, s85, th400 build update-pa040047.jpg
370ci, s85, th400 build update-pa040046.jpg   370ci, s85, th400 build update-pa040045.jpg
Old Oct 5, 2010 | 12:26 PM
Rickys S/C Z28's Avatar
man thing are really looking good! you going to have it done by this weekend?
Old Oct 5, 2010 | 02:33 PM
Mike454SS's Avatar
Originally Posted by trans2000am
this car is still gonna be street driven, ill be happy with 800 to the back tires
Thats my thought process for the 370 I'm building too...putting it in a heavier car though and looking for a little more power to match the weight.
Old Oct 5, 2010 | 02:36 PM
most likely not im off work tomorrow so im gonna hit it hard first thing in the morning. i still have to install the whole interior which im sure wont be fun
Old Oct 5, 2010 | 06:40 PM
JAX04's Avatar
how bout them dimension pics lol
Old Oct 5, 2010 | 08:03 PM
Josh@KY-Turbo's Avatar
I personaly like the Down Pipe. Its the perfect amount of exhaust for a turbo car.
Old Oct 5, 2010 | 08:13 PM
bad6as's Avatar
it is loud thoe.
Old Oct 5, 2010 | 08:41 PM
Loud is the opinion of the owner.
Old Oct 5, 2010 | 08:43 PM
JAX04's Avatar
is that a 3" downpipe?? i thought the turbine outlet was a 5" for some reason??
Old Oct 5, 2010 | 11:27 PM
5 inch downpipe, an ill get you the dimension of the turbo in the morning ran out of time today,ill get a better pic of the downpipe tomorrow also
Old Oct 6, 2010 | 09:18 AM
  #32
JAX04's Avatar
hell yeah, thanks bro
Old Oct 6, 2010 | 07:04 PM
  #33
worked on the car for a couple hours today, go the wiring harness back in the car. Most of its hooked back up doing my best to hide all the wires. got the other upper an lower control arms on an DA coilover.
Tomorrows to do list is to put the rack in pinion back in, finish up the wiring inside the engine bay.
Still need to find out where to locate the coil packs cant mount them on the cowl due to how tall the valve covers are
Old Oct 6, 2010 | 08:11 PM
  #34
JAX04's Avatar
keep it up man, this thing is gonna rock when its done. Hey one more question, whats the over all length of this thing.
Old Oct 6, 2010 | 09:12 PM
  #35
couple shots of the cage, STENOD did an amazing job
Attached Thumbnails 370ci, s85, th400 build update-p7200004.jpg   370ci, s85, th400 build update-p7200005.jpg
Old Oct 7, 2010 | 05:51 AM
  #36
JAX04's Avatar
that looks very nice man!
Old Oct 7, 2010 | 09:56 AM
  #37
trust me its not that loud!! i loved it!
Old Oct 7, 2010 | 09:59 AM
  #38
trust me man it will make more then that with your heads and CI. my car made 700 and i have a stock CI motor with junk heads and a 4L80e with an 8.8
Old Oct 7, 2010 | 06:52 PM
  #39
worked on it about 2 hours today
got the fuse boxes mounted, tied up some loose ends on the car, couple pics of the the turbo mounted again you can see the limited space
Attached Thumbnails 370ci, s85, th400 build update-pa070061.jpg   370ci, s85, th400 build update-pa070062.jpg   370ci, s85, th400 build update-pa070064.jpg   370ci, s85, th400 build update-pa070065.jpg
Old Oct 7, 2010 | 06:58 PM
  #40
has anybody mounted the coils here? bout the only other area i can think of
also a pic of my helper
Attached Thumbnails 370ci, s85, th400 build update-pa070068.jpg   370ci, s85, th400 build update-pa070067.jpg   370ci, s85, th400 build update-pa070066.jpg
