9.3:1 7500rpm dyno pull
Old Oct 3, 2010 | 01:15 AM
TurboAv's Avatar
Default 9.3:1 7500rpm dyno pull
Went back to the dyno and worked on the tune a little. We tried bumping the timing to 33 degrees. It didn't get any KR, but it also didn't help power. So we backed it down to 31 where we left it last time. We also pulled her up to 7500 rpm and got the fueling squared away up that high. My stock injectors are at 90% duty cycle with a stock pump. She also doesn't seem to really move out until 5000rpm on the street. It's almost like VTEC kicked in, lol. Seriously though, it's very noticeable. We are thinking possibly since I had the converter spec'd for a 300hp shot of nitrous it isn't liking being NA right now. Even off the juice it's stalling at 4000 though. It's spec'd for 4600-4800 on the bottle. My tuner want's me to do a standalone and put the spray bar on a 200-250hp shot until I go FI. I'm including an overlay of my old cam and bolt-ons only LS2. To only loose 14rwhp and 13ft-lbs going to a lower compression motor is pretty good I think.
Based on the dyno pull, where should I be shifting my TH400 for the best times? 3.46 rear gears with a 26" tire.
Runfile 2 is the old stock LS2 and Runfile 13 is the new low compression motor.
Here is just the new setup today. It was 99F, 28.49 Baro, and 22% Humidity
Vids:
http://www.youtube.com/watch?v=Da-qRN5Fl10
http://www.youtube.com/watch?v=qsirDvvZCrk
http://www.youtube.com/watch?v=fVUt4lVub-U
Old Oct 4, 2010 | 08:20 AM
moehorsepower's Avatar
First off, why are you spinning the motor to 7500 when it clear that its done way before that?
Old Oct 4, 2010 | 12:57 PM
TurboAv's Avatar
Because I want a baseline for when I add FI.
