Oil smoke on decell
Old Oct 7, 2010 | 07:02 PM
ItsAHOSS's Avatar
Default Oil smoke on decell
I have a 347 LS1 with a t76 turbo,
I did the MightyMouse vaccum set up where you t off the brake booster with a ball check valve into the PCV valve.... on the drivers vc.
then I have a t off the front of the intake into a inline PCV valve to the cover...
I havent pulled and tapped into the valley cover so i am pulling the passenger side vaccum from the front of the intake
I can Idle with no smoke, and drive normal with no smoke... even under acceleration with boost no smoke, but as soon as i let off the accelerator the smoke POURS out the tail pipe
Any suggestions? am i doing something wrong? Is the turbo going?
Old Oct 7, 2010 | 07:38 PM
Busy Mopper's Avatar
where did u find this write up for the mighty mouse pcv setup
Old Oct 7, 2010 | 07:46 PM
ItsAHOSS's Avatar
its here
https://ls1tech.com/forums/forced-in...ac-system.html
Old Oct 7, 2010 | 08:38 PM
98Z28CobraKiller's Avatar
Restricted User
Vent,catch can and breather the valve covers and plug the plug hole in the intake. Change oil frequently.
Old Oct 7, 2010 | 08:45 PM
ItsAHOSS's Avatar
You kinda lost me?
I have the PCV set up, and when i say BLOWING oil smoke... it looks like the motor has let go.... in a dense blue fog
Would you happen to have a diagram of the catch can set up... the oil has maybe 100 miles on it
Old Oct 7, 2010 | 11:37 PM
396375's Avatar
This may not be your problem but most turbos that I've seen go start with smoke on the decel.Check the horizontal shaft play.There should be hardly any.
Good luck.
