Valve springs?
Old Jan 30, 2004 | 04:40 PM
MYTURBOT/A's Avatar
Default Valve springs?
When runing FI those of you that switched from stock springs to the comp.918s or somthing similar. Could you tell a differance in performance? Also did it change part throttle performance any? Thanks.
Old Jan 30, 2004 | 05:18 PM
ChevyNo1's Avatar
DEFINITELY. My car was falling on it's face starting @ 5200rpm. And it did seem that part-throttle picked up also. Re-dynoing tonite since the springs, I will be in the exact same configuration other than those. So comparisons should be easy, I'll let ya know!
- Dug
Old Jan 31, 2004 | 02:24 PM
Noyzee's Avatar
8 second mod
I have the old comp dual springs. and they are great. the new ones im going to use are the 921's, suposed to be the best. little $$$ but i guess its good stuff.
Old Jan 31, 2004 | 03:02 PM
ChevyNo1's Avatar
See my new post here . . .
https://ls1tech.com/forums/forced-induction/134310-620-684-12psi-91-octane-stock-motor-918-s.html
