7K Mile TearDown
Old Oct 17, 2010 | 09:50 PM
TXZ0603's Avatar
Default 7K Mile TearDown
After battling this smoke gremlin, I finally decided to tear it down. This is it for today. This is the passenger side. Ill get the drivers side torn down tomorrow then get the block out. :*****::*****:
New day
Had to cut the gasket out
Old Oct 17, 2010 | 09:59 PM
Tiago's Avatar
you sure it wasn't a turbo leaking before taking the motor apart?
Old Oct 17, 2010 | 10:10 PM
TXZ0603's Avatar
I had a turbo leaking however, it was on the exhaust side. So not ingesting oil. That was replaced by the PTE's This car has smoked from day 1. Was using up to 1/2 qt oil every fill up. I finally had enough.
Old Oct 17, 2010 | 10:51 PM
blk00ss's Avatar
The combustion chambers look awful dirty. I bet you had some bad valve guides/seals.
Old Oct 18, 2010 | 08:17 AM
Tiago's Avatar
if a turbo is leaking on the exhaust side, its burning the oil and smoking.....
Old Oct 18, 2010 | 08:24 AM
Old Geezer's Avatar
Any leakdown test results??
Old Oct 18, 2010 | 09:33 AM
TXZ0603's Avatar
Tiago, tho old turbos were leaking. The new ones are not yet the motor is still smoking and consuming oil worse.
Leak down on yielded 10% on #7 and 15% on #2. In my experience that has not been enough on its own to yank a motor. With the massive oil consumption and smoking is why I am pulling it.
Old Oct 18, 2010 | 09:45 AM
Boo"SS"t's Avatar
I'm assuming you have a good scavenge pump for your turbo's drain system and restrictors in oil supply?
 Michael S. Palmer
Old Oct 18, 2010 | 09:49 AM
c6matt's Avatar
exactly what i was thinking..
Old Oct 18, 2010 | 11:09 AM
BadgeZ28's Avatar
Considering the resolution of the pictures on my monitor, I don't see anything of concern on that bank. Did you do a leak down test first?
Old Oct 18, 2010 | 12:26 PM
TXZ0603's Avatar
did a leak down That bank was good. I added new pics o the drivers side up top. Looks like all of them are oil soaked.
I am using a gravity system on the turbos with -10 returns and restrictors are built in to the 62-65s. Ive checked the returns and had no blockage
Anyone suggest some good rings for a 3.905 bore
Old Oct 18, 2010 | 05:06 PM
Boo"SS"t's Avatar
Were any of your spark plugs getting fouled from the oil? and what kind of twinturbo kit do you have?
Old Oct 18, 2010 | 05:11 PM
lavoy's Avatar
my turbo ls1 uses half a quart to a tank of gas as well. but my motor is very tired and has well over 100k on it. it also only smokes on decel. i hope you find whats wrong with it.
Old Oct 18, 2010 | 05:30 PM
TXZ0603's Avatar
plugs 5,7,2 showed oil spots on them.
The turbo kit is custom built, similar to the HP kit
I should have it at the new builder by this Friday.
