turbo size for a 5.3l ?
Old Oct 20, 2010 | 10:01 PM
gallo-lo's Avatar
Default turbo size for a 5.3l ?
im looking in dropping in a 5.3 truck motor with a 350th 0r 400th in a 93 volvo 240 wagon ,slippin in a ford 8.8 rear 3.55 gears. ihavent figure TC, AND cam yet, i have a turbo that has been sittin for a while its a t6 A/R 1.08 with a 75mm compress side i was thinkin of using it with the 5.3 set up, i figure a 5.3 with ls1 heads (241) i should get enuff boost, i will using ARP bolts on the rods and bettter head gasket , and heads arp studs, what is a good cam for the 5.3 under boost? i m looking into 9.5 tc with the transbraek,my goals are 550 to 600hp using stock pcm with good tunning and more inectors size. im open to great helping opinions and realistic thanks
