Safc 2
Old Oct 28, 2010 | 12:47 PM
murdock.dean's Avatar
Default Safc 2
So i hooked up a wideband A/F guage and found out my car is runnin lean (12.0) under wot. My buddy has apexi SAFC 2 and we were woundering if I could use that to fine tune the car. A/F is good everywhere else just lean under WOT. Car has a turbo 5.3, walbro 255, 60lbs injector and runnin 85 psi at the fuel rail so im better sure it not leanin out due to fuel pressure drop. Only runnin 10psi of boost. Has a 2 bar MAP sensor too. So we just woundering if the apexi SAFC would work on the car to fine tune the WOT A/F. thanks for any input.
