head bolt question
Old Nov 1, 2010 | 07:12 PM
RNation0001's Avatar
Default head bolt question
ok im doin a moderate boost build. hoping for around 12 lbs of boost and my question is what head bolts do i need for the 317 heads? i noticed arp has different head bolt packages for 2004 and below and 2004 and above
Old Nov 1, 2010 | 07:14 PM
JAX04's Avatar
youll need to see if you have equal length head bolts or two per head that are shorter.
Old Nov 1, 2010 | 07:52 PM
BADBOB's Avatar
yeah the difference in the head bolts are in the block. FWIW i was recommened to get studs bc with a alum block it pulls the 2 together better and not try and pull the threads out the block
Old Nov 1, 2010 | 07:57 PM
i got an iron block 5.3 bored to 5.7.
