Will Cartek H cam work in a SC application
Old Feb 2, 2004 | 10:57 AM
TriniJoe's Avatar
Question Will Cartek H cam work in a SC application
I have a 98 vette 6-speed with Cartek stage II head/cam (INT-222 EXH-226 .567" LIFT, 113 LSA). The compression is about 10.8:1. If I change the heads to the PP stage II perimeter bolt heads that yield about 10.1:1 compression, can I use the Cartek aforementioned cam in a supercharger application.
Old Feb 2, 2004 | 11:20 AM
BIGBOS's Avatar
Go with some 6.0L heads with some 73cc chambers to get your comp lower and you shouldn't have a problem, I popped a head gasket with 10.6:1 comp on 6psi.....high compression and boost is playing with fire......
That cam doesn't look too bad for a boost application, I would try it for now and see how it does.......
Old Feb 2, 2004 | 11:23 AM
sr71's Avatar
absolutely. it should make a great supercharged cam in the real world.
