After Market K-Member VS Solid Mounts
Old Nov 5, 2010 | 05:49 PM
IT_SS's Avatar
Default After Market K-Member VS Solid Mounts
Trying to get a feel if its worth it to purchase an after market (UMI, BMR) k member vs using solid mounts. Is there a huge difference in down pipe routing? Can it be a justified expense for a street/strip car? Thanks in advince
Old Nov 5, 2010 | 06:41 PM
Josh@KY-Turbo's Avatar
I run 4" DP on Stock k-members with Sphon sold stands every so often. It is tight but it works. The BMR Turbo K-member will allow you to run a 4" DP easily, and a 5" with some monor Notchin on the DP if going over the Drivers side.
Old Nov 5, 2010 | 07:01 PM
IT_SS's Avatar
thanks josh, you da man!
