How to Clock turbine on TC78
Old Nov 15, 2010 | 09:20 PM
JAX04's Avatar
Default How to Clock turbine on TC78
question, i know how to clock my compressor housing, but i need to be able to clock the turbine side so that oil inlet and oil outlet or vertical, right now, there is a slight angle to it, and id feel more comfortable with them being perfectly up and down??
can it be done??or am i strictly limited to the bolt holes on the turbine side??
Old Nov 15, 2010 | 09:24 PM
mike13's Avatar
Don't you clock it the same as you would the compressor housing?
Old Nov 15, 2010 | 09:26 PM
JAX04's Avatar
seemed to me that i couldnt even remove all the bolts, since two of them are under the corner of the center section. but the ones i removed looked like they went "into" the housing itself, through the bracket
Old Nov 15, 2010 | 09:29 PM
HydroStream6's Avatar
Just loosen the bolts. They don't have to be removed. If for some reason you do need to remove them, loosen them all, clock it to where you can access the ones you couldn't get out before, then remove them.
Old Nov 15, 2010 | 09:30 PM
JAX04's Avatar
no **** huh, just didnt look like that would work on the turbine side, of course, i admit i ddint get to into it, since i had someone here that was getting busy, and needed the turbo to mock up the flange, lol
Old Nov 15, 2010 | 09:34 PM
Yep, as long as it's like mine and 90% of all the other turbos out there, should be just like the cold side.
Old Nov 15, 2010 | 09:37 PM
JAX04's Avatar
well, when i take my fat *** down stairs next, ill give her a go, lol
Old Nov 15, 2010 | 09:57 PM
mike13's Avatar
It's tough to get a wrench in there sometimes, I've had to grind down a wrench to fit in between the bolt and the fittings on the center section of the turbo. If it's a used turbo it might take some liquid wrench and some finesse to get the turbine side to move.
 Michael S. Palmer
Old Nov 15, 2010 | 11:58 PM
eviltwin_1987's Avatar
i had to tap my housing with a rubber mallet to get it to turn when my tc78 was new. it was TIGHT
Old Nov 16, 2010 | 06:19 AM
JAX04's Avatar
thanks guys, ill give her a shot tonight, it is brand new, so hopefully it wont be to bad.
Old Nov 16, 2010 | 08:40 AM
yelo04goat's Avatar
just remember let me know when you plan to go bigger...
i will be sitting here for the next 4 1/2 months while deployed watchin your build so i know where your running it to problems...
thanks for doin all the leg work!
Old Nov 16, 2010 | 08:47 AM
JAX04's Avatar
no problem, and if you ask me, your doing all the leg work for us! thank you for your service.
Old Nov 16, 2010 | 08:55 AM
yelo04goat's Avatar
just a job man... i just work on f-18s
its fun.
