Wideband not working or is this normal?
Old Nov 17, 2010 | 05:50 PM
sschoeffler's Avatar
Default Wideband not working or is this normal?
Just installed the wideband today and turn the ignition on did its little calibration then went all the way to red and the screen displayed ---. Started the car and the same thing, nothing changed. Now the car has open headers and its probably 4-5 inches from the end of the collector. I called AEM and they said it was normal for it to not read or read too lean to display on the AFR gauge. I just wanted to make sure that I would infact get no reading or if I should be getting a reading. Surely I am not the only one who has put a wideband in open headers.
Stephen
Old Nov 18, 2010 | 10:27 PM
twinturbo496's Avatar
Stephen
Do you have an MSD box?
The LM1 Innovate box I have will not accept the A/C noise from a MSD box...
Old Nov 19, 2010 | 08:56 AM
TracyRR's Avatar
yes, my AEM does the same thing when it is cold.... it is off the chart lean so it reads ---. When it is super fat, it just sits on 10.0..... Best of luck
Old Nov 19, 2010 | 10:12 AM
black98ws6ta's Avatar
If it is 4-5 inches from the end of the exhaust it will get saturated by the outside air. At higher engine speeds it will be better but most would run some sort of extention on the exhaust.
Old Nov 19, 2010 | 09:14 PM
CarsandWomen's Avatar
^^^this, your wideband is getting readings from the air outside the header, where there is LOTS of o2, so it says lean. put an 18 inch collector extension on there and you should be fine
Old Nov 20, 2010 | 01:02 AM
mwg2600's Avatar
Yes try this.
