T88 system pics.
I sectioned/boxed the core support so the radiator sits inside it. The radiator is nearly vertical.
The front 5 inch downpipe section goes around the framerail (through the factory hole that the coolant resivoir once occupied.)
We will have pics of it installed in the car soon.
We use a local source for ceramic coating. We typically use a higher temp rated black coating ni this type of application, but i think the silver looks alot nicer, so I figured we see how it holds up.
Tom
it does though help flow when you have it big then taper it down if compared to one standard size.
Im speechless.
