pump gas limit without methnol
Old Dec 5, 2010 | 01:16 PM
'Trust''s Avatar
I made 773rwhp at 18psi with 91 and no meth, but it was SKETCHY, 1 bad tank of gas and boom. I put a alkycontrol kit on it to be safe, then started filling up with 101 when the car was making 808rwhp. All that money in parts etc. is worth the extra $20 on a tank of gas.
KissMySSo1's Avatar
i made 780 rwhp at 15 psi 14* timing with a fmic and 346ci. on straight 93
Old Dec 5, 2010 | 08:00 PM
bravolistick's Avatar
730whp 750wtq @ 14lbs and 18* on 91pump w/ Forged 6.0, twin GT3076R's, 72lbers, walbro, and BAP... stock heads, stock cam.
Old Mar 23, 2011 | 11:41 PM
pdasterly's Avatar
nice numbers everyone, decided to add meth. Going to tear down car and add bunch of parts, tubular engine crossmember, tubular upper and lower control arms, ported intake and throttle body, clean up my vacuum lines, add vacuum manifold, add three gauges to center a/c vents, swap rear end for 6 speed rear and aluminum driveshaft. Also going to swap in procharger fan and make an intake for the procharger, just waiting to get car back from shop, trans wont shift(valve body is sticking). I want to powder coat my charge pipe and have the meth and iat sensor bungs welded in, also might have shop extend charge pipe to completely do away with maf, since im speed density anyway.
Old Mar 24, 2011 | 08:50 PM
tomz28's Avatar
i just made 690whp on 93 oct no meth.
16psi, the engine is 364ci, 8.7 to 1 CR with 18degs timing
unlocked 4L80
