Rear Mount Questions
Old Dec 12, 2010 | 06:35 PM
GMouldy's Avatar
Default Rear Mount Questions
I have an STS kit right now, and becoming slightly over whelmed with all the wiring, from the kit itself, to the EBC, and the Meth injection.
has anyone here every tried to eliminate most of the wiring? As of right now, i have bypasses the resistor for the high/low speed scavenge pump. so i don't really see a need for all those relay's under the hood, except for the PCV valve. But i've read on here guys removing the PCV valve for a catch can.
the meth injection kit is pretty confusing to (To me it is anyway) just in the way how it works together with the EBC to only inject under high boost.
Just wondering what some other people have done.
Old Dec 12, 2010 | 07:11 PM
JAX04's Avatar
I would def start by eliminating that "pcv solution" that they think they have, grab up a lashaway can or something of the like.
Also, you want relays for the meth and for the oil pumps.
just take your time and use the relays and use fuses.
i know wiring sucks, but its something that should be paid the most attention too. Just make sure you have good solid ground points, try to put the wires in a pinch and youll be fine.
Old Dec 30, 2010 | 10:06 PM
kornboy's Avatar
You need to just throw away that STS methanol injection kit.That kit works but it is overly complicated for no reason! BUY A SNOW!!That what i did.Ok i didn't throw it away, i sold it!!
Old Dec 31, 2010 | 06:28 AM
Cold06's Avatar
LOL whoops had to dig it out did ya LMFAO
