intercooler piping A/W
Old Dec 16, 2010 | 12:06 PM
lsjake's Avatar
Default intercooler piping A/W
im building a 5.3 with 317 heads, zo6 cam, edelbrock vic jr, and a single s400 83 mm 1.10ar, and a th400 with a break. i am going run a air to water intercooler in the trunk (g body car) i was wondering what size pipe, and is it worth almost double the money to buy the aluminum pipe vs the mild steel?
Old Dec 16, 2010 | 12:32 PM
GhostofKrypton's Avatar
Material only matters for weight. Size of the tubing matters more. I wouldn't go any less then 3" in size, I would also spend more for aluminum, because of the weight. Check on ebay, they are always selling intercooler piping kits.
Old Dec 16, 2010 | 12:48 PM
lsjake's Avatar
thanks, i couldnt find anything in 5' lengths i need to run it to the trunk. i was planning on running 4" round, i think i will stick to that. i know this all seems a little overboard for a stock bottom end 5.3, but i want to do all this right away so i dont need to redo everything when i finish my 370ci. this is my first boosted build. thanks for the help
Old Dec 16, 2010 | 02:36 PM
MaxxMitchell's Avatar
If you are wanting to do it only once, stick to 4" aluminum, and make sure the core on the A/W is large enough for your future goals.
