stock ls1 turbo
if i cant make enough power out of a turbo without breaking stuff, i cant see the point doing all that work for a stock motor.
it looks like it will be much cheaper to get a set of good heads and just bolt them on. my cam is a comp 233/239 112lsa. ive seen alot of people make great numbers on that cam with some heads. even with just ls6 heads. its also far less work. what do you think?
What are the goals of the car?
the 112LSa is low for boost. Look into a 114 or higher.
1.) Sell your LTs, cam, intake and whatever other "boltons" that won't be needed.
2.) Find a used (or new) turbo. A T60 will do 500whp, a 70 would be better.
3.) Get yourself some 60lb injectors and a Walbro 255. Rails and a return reg would be nice but not crucial if you're on a budget.
4.) Get some 6L manifolds and an assortment of piping.
5.) Get oil lines, wg, bov. You can find used stuff for ~1/2 price if you look.
6.) Get an 02+ LS6 cam and 918 springs or better with some hardened pushrods.
7.) Get a set of MLS gaskets and ARP bolts, studs even better.
8.) Get a set of ARP rod bolts. (Oil pan will be off when you tap it for the oil return anyways)
9.) Get an ebay FMIC and cold side pipe kit.
9.) Get a few cases of beer and a few buddies and get to work.
500whp is easily obtainable and with the precautions mentioned above, it should live for a while at that power with a good tune.
what heads did you run?
