4.8 combo, looking for a little help.
Old Dec 20, 2010 | 05:30 AM
Slowmo_Bird94's Avatar
Default 4.8 combo, looking for a little help.
I want to get a 4.8, add ARP hardware, LS9 head gaskets, LS6 cam, springs, and intake. Also in the plan is a 76 mm ebay turbo and making my own kit running 10-12 lbs.
Does anyone know off hand what heads come on the 07+ LY2's? Are there any options down the road for more power heads wise?
I know the LS6 cam will go in a 5.3 all day long with no problems, is this true with the 4.8?
I am absolutely clueless about injectors, HELP!
What approximate power range should be attainable with this combo? I would think the bottom should be safe to about 600 RWHP as a 5.3/6.0 would, correct?
Old Dec 20, 2010 | 05:34 PM
Anyone?
Old Dec 20, 2010 | 05:44 PM
skyhighsami's Avatar
no title here
Since a 4.8 is a truck motor cruise over to performancetrucks.net and look at foose04.
Old Dec 20, 2010 | 05:45 PM
RibeiroBJJ's Avatar
-Get arp rod bolts, skip the ls9 gaskets and use stock mls,ls6 cam is good,and what intake? 4.8/5.3 heads are the same and the ls6 cam will go into any gen3 motor
-If you want to lower the compression some put some low cost 241 heads on there
-For 600rwhp you will need a minumum of 60lb injectors with a return fuel system with the appropriate pump...you could easily reach your goal with 15psi
check out performanrtrucks.net for more 4.8/5.3 info......
Old Dec 20, 2010 | 05:48 PM
no title here
Ah ha I won!!
Old Dec 21, 2010 | 03:36 PM
My objective for this build is a baby step... I will eventually swap the 4.8 for a 6.0 aimed at the 900+ hp mark. I want to get some extra power, but not so much that I destroy a poor little motor for nothing. I need the motor to last a while, so I figured that 10 psi and a good tune should hold me over.
I have seen the ls6 intake used on the 5.3 for boost, I figured it would be a safe bet.
If I get some 60lb injectors and run closer to 500hp rather than 600hp, I should be gravy, right? My uneducated guess is somewhere around the 500rwhp mark on 10 psi. Can anyone confirm this?
Old Dec 21, 2010 | 03:51 PM
tripblackls1's Avatar
why skip the ls9 gaskets?
ls9 gaskets are close to same price as reg mls but designed for boost i see no reason not to use them
Old Dec 21, 2010 | 03:57 PM
TransAmatt99's Avatar
My truck is an 07 new body style, and it has the 243 heads on it. Which should be good for your setup, just have them ported. Injector wise I have some 71#s for sale which took my car to 650rwhp without any problems.
Old Dec 21, 2010 | 03:59 PM
IT_SS's Avatar
the newer 5.3/4.8s come with 243 heads
Old Dec 21, 2010 | 04:00 PM
honestly for only 10 psi i would not even bother changing your heads unless there already off because most 4.8 motors are 9-1 comp ratio from factory.
As far as injectors if your planing on a 900 + hp build later i would buy injectors that you would use for that build (like 100 #) there is no sense in buying injectors twice and with a good turner they should work fine for this build
also you should be 500rwhp range at 10psi but there is a number of factors
main ones being your tune, your parts selection, and drivetrain
Old Dec 21, 2010 | 04:24 PM
Well, I do not even have a motor yet, I was hoping to pick up a 4.8 with my tax refund. I know where one is for $350. I have a 94 Firebird Formula, but I am not sure if that will be the project car or not.
I am going to get the motor the way I want it before I decide what to put it in. I was thinking of building the 4.8 later on, but the 6.0 has more potential, so the 4.8 will not get a set of heads. Just cam, springs, head gaskets, and intake for now. I will then swap parts to make it fit in what I decide. After that comes boost.
Old Dec 21, 2010 | 04:34 PM
the 4.8 are strong motors, ive seen / heard of stock bottom end 4.8 making 800+ hp
for how long idk lol
as for mine im looking to make at least 700rwhp with e85 at probably 18- 20 psi and that is a stock bottom end 4.8 with arp bolts and ls9 headgaskets and 317 heads
Old Dec 21, 2010 | 08:27 PM
From what I have heard and seen, 600rwhp is about the "safe" limit on the bottom end with a good tune. That is where I came up with my goal of just over 500 rwhp.
Old Dec 22, 2010 | 05:04 PM
So is everyone pretty much in agreement that I may have a decent combo lined up here? 4.8, LS6 cam, LS6 intake, LS6 valve springs, LS9 head gaskets, and 60+lb injectors for about 500-550 rwhp? It will be a LONG time before I get to the big time build, so I just need the right injectors for now.
Old Dec 24, 2010 | 08:30 PM
So I heard that the LS6 cam has a smaller base circle (.050) than an LS1 cam. Does this apply to the cam in the 4.8? Will I need longer push rods?
Old Dec 25, 2010 | 03:36 AM
kmracer's Avatar
that honestly wouldnt make ANY sense. where did you hear that?
Old Dec 25, 2010 | 07:27 AM
http://sdparts.com/details/gm-factor...parts/12565308
Right there in the print. Apparently the LS6 has a longer valve stem? Doesn't make sense to me, but I have a lot to learn too.
Old Dec 25, 2010 | 05:55 PM
kmracer's Avatar
well god damn. i have zero experience with the cam, i couldnt tell you. but i've never heard of anyone running into problems. in any case, check wipe pattern before you run it.
Old Dec 25, 2010 | 06:16 PM
I suppose I will check on some numbers with a company that would have the proper information... I know Scoggin Dickey is a well known company.
Old Dec 29, 2010 | 07:31 PM
Change of plans: found a 5.3 for $275 with an LS1 intake. Same bore as a 4.8 at 3.780 right? I hope to still use LS9 head gaskets.
