Twin 6765 408 88 GTA build Been working on this build for a little while... 1988 GTA 305/700R-4 220K miles before it gave out... 2001 LQ9 bored out to 4.030 Mahle Pistons/Mahle Performance rings Callies 6.125 rods Callies Compstar 4" stroke crank flowed 317 heads(325cfm) from 67firebird455 Lingenfelter intake with 4 bolt LS2 90mm TB adapter LSX Fuel Rails 83lb Racetronix high impedance injectors 034 motorsports standalone Stainless works turbo manifolds Precision billet 6765 turbos Tial 44mm wastegates Art Carr 200-4R/Art Carr Converter QP 9" rear Here are some pics mocked up for now... http://i219.photobucket.com/albums/c...01221-1343.jpg http://i219.photobucket.com/albums/c...01221-1343.jpg http://i219.photobucket.com/albums/c...5/DSCF0455.jpg http://i219.photobucket.com/albums/c...5/DSCF0453.jpg http://i219.photobucket.com/albums/c...rty85/gta1.jpg http://i219.photobucket.com/albums/c...rty85/gta2.jpg |
nice mock up cant wait to see some snail hanging! |
They will be hanging soon, just have to source the correct precision flanges because the turbos are vband inlets and precision wants to be different than everybody else... |
Got the crank installed and the headers back with turbos hanging on them Next gotta gap the rings, and put the pistons and rings in http://i219.photobucket.com/albums/c...10122-1953.jpg http://i219.photobucket.com/albums/c...10122-1923.jpg |
Nice........what tranny will you be running? |
im a big fan of lsx gtas, especialy one with forced induction.:devil: im working on my own ls sc gta |
Anyone have a recommendation on ring gap for 14-20psi? I also plan to spray a 150/200 shot if I have too. I set the main bearing clearance for .002 and rods will be .0025. I was thinking .0028 to .0032 for the top ring, and .0022 to .0024 thousandths for the second ring. Is this too loose for just boost? Oh yeah, I measured all my parts going into the car and with me I calculated 2471. With a cage, I think I should be just about 2600. Is this thinking too low, or is this really possible? |
I'm liking this...can't wait to see the finished product. How often do you plan on spraying? I would space things according to psi rather than spray...be it that the motor will live on psi all the time. |
Still deciding on the tranny.. want to run a 200-4r like TTA's had and art carr makes one rated to 1k with a tc for 2617. That way I can run the crossmember from spohn for a close match. Or a 4l80 with a little tunnel cutting. |
Nice build! What engine management system are you going to use? BTW, I noticed you're in Chesapeake, I graduated from Indian River in 04'. |
The engine management will 034 motorsports IIC. I have a whole system left over from a vr6 build. It will support up to 16 cylinders, batch fire, rotaries, waste spark, and supports all gm sensors. It also has an integral two step and spark cut. It was around 2400 for everything. Im trying to go to kings bay for my next orders. |
Haven't heard of that one. I've been here going on a year, it's not too bad. When's your time up there? |
The 034 IIC for the money is one of the more advanced standalones in the world, here is their website:http://www.034motorsport.com/034efi-...dp0ksqhdjmfr50 I transfer in oct this year |
If I had to buy one, I'd look at the Holley dominator setup. Good luck with your orders. What's your rate? |
I'm a Fastboat Radioman. Trying to go to a GN. Still trying to see what the detailer has for an ET1 on the florida of georgia. |
Originally Posted by kurty85
(Post 14409320)
Been working on the engine buildup, got the rings gapped to .028 for the top ring, .021 second ring, pistons and rods installed, valley cover on, knock sensors in, waiting on a timing set now due to getting a 1 bolt cam by accident, then I can mount the oil pump, pickup, pan, and hopefully have some lifters by then(thunder racing sucks) http://i219.photobucket.com/albums/c...10130-1727.jpg http://i219.photobucket.com/albums/c...10130-1727.jpg http://i219.photobucket.com/albums/c...10130-1729.jpg http://i219.photobucket.com/albums/c...10130-1728.jpg |
Looking good. |
You may want to ask some people but from what I remember reading you do not want your 2nd ring to be a tigher gap than your top ring on a boosted setup. Something about pressurizing the top ring and causing flutter. |
those headers tapered down into the turbos like that is going to be pure insanity! looks good man, there will be many butt hurt people out there once it hits the streets haha. one thing i did notice though, are the headers super close to the valve covers or is that just the picture makin it look close? |
© 2024 MH Sub I, LLC dba Internet Brands
