convince me...SC or Turbo
To the OP:Im partial to the procharger world because I have one lol. I have never installed a kit before and I did it all myself in the shop. Was really easy and simple as everybody has said in this thread. Wish I had the coin to upgrade to a F1 series blower. Im running a D1SC right now at 16 psi and the car made 780rwhp and it is a blast on the street with a 6 speed. Any route you take will be a good one. Ive been tempted to make my own truck manifold kit with a PT88, but we'll see.
With the cam that I have in there right now the car bucks at low speeds so I just find it easier to stay in first or second. Just got an EFI Live V2 to start tuning to take care of that and a few other bugs but found the last tuner locked the PCM. So now Im waiting on another PCM so I can start from a stock tune and go from there...
True. Except Id have to wait for the unit, intercooler, piping, t-bolt clamps, couplers, brackets, boost guage, injectors, another fuel pump, meth, and all the other misc **** Id need to ship before I could install and fabricate what I needed...Which alsways seems to take for-ev-eeeeeeeeeer...Then Id do some tuning and end up blowing up my rear or trans and be stuck in BFE. But your probably right, I woulda coulda been done with something
To tell you the truth the more I think about it the more Im liking the procharger...leaning towards an F-1R if I do go that route. Done the turbo thing, maybe I should give the SC a try
Superchargers are broken into three groups.
centrifugal- these are (IMO) the worst type of supercharger. They use a linear boost system, which means you get more boost as your rpms increase. they are similar to turbos in design but are still belt driven.
Roots- theese use two meshing lobes to compress air and cram in into the engine. the lobes, however are "old technology" but they still grant maximum boost instantly when you put your foot in. may be some clearance issues under the hood.
Twin screw- (my personal favorite sc) almost the same as the roots type but instead of lobes, uses two meshing screws and is much more efficient. still instant boost, still may have clearance issues, and has good boost throughout the rpm range(kind of drops off at the end)
unfortunately s/cs, because they are driven by belts attached to the engine, have a parasitic effect on the engine. because of this, at high boost, a s/c will likely have about an 80hp difference (s/c being lower) from a turbo at the same psi. and superchargers cannot reach boost pressures as high as turbos have the ability to. also may have issues with belt slip at high boost.
Turbos-the issue of lag is mostly eliminated, roots/screw s/cs tend to do better at the lower end. turbos can reach insanely high boots levels(ive heard of some being as high as 72psi.) turbos are more efficient, however depending on what you are looking at doing, long or short runs, i hope this proves helpful. im sure ive missed something but thats what foreums are for!
Havent seen much on the twin screws for the f-bodies...maybe someone can enlighten me. Only thing I guess I really worry about is the lack of cooling down the IAT's since the air is compressed and forced into the motor right before combustion happens...at least with a centri sc or turbo I can cool down the IATs, reasonably speaking, which will need to happen on 120*+ days here in Yuma, AZ during the summer
And on that note, I'd suggest anyone running or planning to run a decent amount of power do yourself a favor and plan on a SD tune from the start. I could have avoided a lot of headaches and money trying to bandaid over the MAF crap!
My $0.02...After having one of each (S/C and turbo) I would go turbo.
Can't speak about Centri blowers but I had a factory Roots S/C car (grand prix) that was fully modded to the n-th degree and adding all that time and cash up and I could have had the same power output with the base turbo conversion kit for 2/3rds (or less) the cost and still had the potential for more power and maintain the reliability of a factory delivered car. I hated the belt flap and constant belt slip both which chewed through belts faster than a puppy with a new pair of shoes. Pulley changes were a PITA even with the quick change setup and changing the oil was messy. I required having several belts and a tensioner tool on hand at all times to go with the pulleys 'cuz i might want to change to a new size if i had a batch of bad gasoline and had to downsize due to knock.
Turbo, most of it can be done with a push of a button or twist of a ****. The only thing i can agree with is the others that have posted about chasing boost leaks or cursing cheap fittings when they dribble due to poor manufacturing.
Once the complexity of the exhaust routing and fully wrapping everything to stop melting is taken care of turbo is smooth as silk!
Most people complain about lag. Well, I like it because most of my driving is in the lag so I don't burn fuel anymore than if I had a stock engine. When i want to bang the gears, I rev it into boost and give 'er. I also like the sound of the turbo more than the S/C...however the whipple is a sound I like!
To each their own.
Good luck with whichever solution you choose!
I have even had roots supercharged BBC car in the old days.
My thoughts ,both of course work and work pretty well.Procharger cars are running really fast at local tracks. The way they build boost by rpm likely helps them get traction especially on the street. They seem pretty simple to install and they seem pretty reliable but some do have some belt slip issues and some do order think aftermarket belt tensioner setups to stop this.
Turbos of course have much bigger area under the curve than centrifugal supers. Huge differences as turbos will come into full boost at say 3000rpm and then hold that till redline.You of course have option to ramp in boost by gear,time or rpm with good controller.And variable boost is pretty nice so it helps with traction like the rpm boost on super. Sure supers might not be as effiicient and you might need higher boost for same hp as turbo but really dont' see that big a deal with that part of it. And think most cranks can take the strain but guys do think pin the cranks at higher power don't they?
roots and twin screw types also work pretty good with as said the twin screw types doing better up top. These can beat turbos at really low rpm since they can have boost like off idle which turbos can't ,at least with current tech.
But this super torque off idle can make roots and twin screws really hard to hook up down low.
Turbos can be more involved to install but so what. If my install took a week taking lots of time whats the big deal. After that week its installed and don't much matter. I like the sound of turbos a lot and blow offs. Of course you can have blow offs on supers as well. I like the sound of supers on boost but some at least some older atis seemed to have really awful idle gear rattle.not sure how the newer ones are for this but I hated it. Roots or twin screw usually don't have the rattle. I loved my huge 6.71 blower on my BBC .That was pure Mad Max time ,sounded great,no rattle and wicked power but did lay down on top but hey BBC don't usually need to be revved to the moon to make big power.
And if you really want some fun go with nitrous ,small shots work fine like 50,75,100 and you will get pretty much instant spool up on the turbo even if using a pretty big one.
Turbo
Pros:
Adjustability "on-the-fly" (planning on electronic boost controller if I go turbo)
Holds boost to up to redline
Stealthier if you want it to be
No parasitic power loss
Cons:
Tight fit for single (Id use a Griffin radiator and stand it up, proven time and time again to work)
Lag (Not really an issue to me but some would argue its a con)
Underhood heat issues (Plan on ceramic coating all the hotside pipes, housing, and manis)
Longer downtime for fabrication and install (Time is time, Id do what I could when I could)
Exhaust leaks effect performance (check system regularly)
Boost leaks (t-bolt clamps and checks)
SC (thinking procharger here)
Pros:
Linear power
Boost is instant, no lag
Easier/quicker install
Cons:
Belt slippage (Seen the Aster bracket, probably would buy one to minimize belt slippage along w/ 8-rib pulley system)
Parasitic power loss (Cant do anything for this one)
Pulley replacement/change to adjust boost
Boost leaks (T-bolt clamps and checks regularly
Anything I missed? Fill me in.
Chris
