Efficiency of the FI setups out there II (Final Results)
I believe this number is inflated. The reason being is that the stock motor will not ingest a full 1 atmosphere (ie 14.7 psi absolute) all by itself. A stock motor (or any motor with an obstucted intake path) will pull a vacuum on the intake rather than the pressure in the manifold being atmospheric. This reduction in manifold pressure greatly reduces HP.
With that being said low boost numbers are going to be inflated because the boost pressures that we are reading are for + atmospheric only. So a 3psi motor is actually:
3psi + amount of pressure to bring the manifold to atmospheric.
So we are actually talking about ~5psi because it takes about 2 psi just to bring the inlet manifold to atmospheric pressure.
If you redo the calculations including the additional psi it takes just to bring the inlet manifold up to atmospheric pressure then your HP/boost numbers drop back down to normal values.
JMO
JMO
great list!
also curious, if you are interested in my turbotech street kit numbers or qmp kit numbers pm me.. dunno if they should count or not?
great list!
Sure, U got a PM.
ALso I didnt make the list to make people think their kits sucks.... Im sorry if someone was offended. If u guys want me to take the list off, its ok by me.... I just thought it was a good refrence for us LS1érs.
I just wanted to provide an explanation for the 30+ HP/boost numbers that were showing up.
I don't want to drag this great thread off track with another long winded thread, so I'll just keep my .02 for this one.
Your doing a good job, keep it up.
I do agree with NoGo with the low psi high RWHP per lb. Makes since to me. Looks like the Vortech G-trim numbers are lower than ATI.. Hey Blacknight you hear that??
Clint
547 - 335 = 212 / by 11 = 19.2 per psi.
Also Another one for ya..
My motor 99' SS Bone Stock with Billet Flywheel, Slp LT Headers, No Cats, LS1 Intake, LID w/ K&N Filter, MAF Ends & ASP UnderDrive Pulley Pulled 328 RWHP. I then added my ATI P-1SC-1 w/7lbs of boost. Dynoed 524RWHP.
524 - 328 = 196 / 7 = 28 per psi. Another high RWHP per PSI Calculation. But it's the truth.
Clint
The only way I could see it working is if every car was exactly the same with the exception of the form of FI. Then you could compare a psi to psi scale.
You also have to think even that isn't the best way to determine what car is going to be the fastest at the track since your basing the calculations on peak hp.
Great work though.
Great work though.
I like your Thread here. It's good general info. Of course many people will say it really does not prove anything. I think it does. If you take many examples it does in fact show an avg per kit. Yes some cars may show more than others, however with many car being used in your list, the avg becomes more important..
Good work, and I know your taking your sweet time to post this info. Thanks again.
Clint
Gary
All you need to know to determine the efficiency of a specific FI system are the RWHP before and the RWHP after and boost. Its just a matter of crunching the numbers.
Looking at the P1SC numbers that Hugger SS posted.
524 RWHP Supercharged
328 RWHP Naturally Asprirated
7 psi of boost
The efficiencies of the above system:
SYSTEM Volumetric Efficiency 119%
MOTOR Volumetric Efficiency 84%
INTERCOOLER Efficiency 81% (interpolated for standard atmospheric)
SYSTEM Flow Efficiency 87% (1.16 psi lost due to system eff.)
It's a good list. And shows some pretty significant things. Check out all of the systems without an intercooler
