98-99 manifold
Old Jan 22, 2011 | 08:23 PM
mike13's Avatar
Default 98-99 manifold
I have a custom made rear mount with a ST80 turbo, do you think having 98-99 exhaust manifolds is hurting performance over using 2000-02 manifolds?
Old Jan 23, 2011 | 12:52 PM
kornboy's Avatar
I was thinking this same question. I would think so, but iam just guessing.Maybe by switch to the beefier cast style we could spool alittle faster?
Old Jan 23, 2011 | 10:34 PM
mike13's Avatar
I know, but when you look at how small a T4 flange is it makes you question if it really matters.
Old Jan 24, 2011 | 05:22 PM
gnx7's Avatar
Just clean up the entry ports into the manifolds with a grinder and they should be fine for what you are trying to do.....
Old Feb 17, 2011 | 10:21 PM
mike13's Avatar
anybody else have any input?
Old Feb 17, 2011 | 10:37 PM
52172's Avatar
their fine..... actually better than long tubes or shorties... no need for any work at all.
Old Feb 17, 2011 | 10:44 PM
mike13's Avatar
I've heard the 98-99's don't flow well, I didn't know if it mattered on a turbo set up.
Old Feb 17, 2011 | 10:52 PM
52172's Avatar
it is true they don't flow as well as the improved 00-02 manifolds, but for your aplication they will not be a restriction at all. In your application you want maximum exhaust velocity which your factory manifolds will provide. Maybe even better than the 00-02 manifolds..!!!!!
 Michael S. Palmer
Old Feb 18, 2011 | 12:13 AM
NemeSS's Avatar
It should help if they are wrapped with hi temp fabric. And also wrap rest of hot parts.
Old Feb 18, 2011 | 09:05 AM
mike13's Avatar
The rest of the hot parts have header wrap, I haven't done the exhuast manifolds, thinking of maybe ceramic coating them.
Old Mar 13, 2011 | 11:49 AM
mike13's Avatar
any other comments? You think it keep me from making 700rwhp with a ST80 turbo?
