first time turbo
Old Jan 24, 2011 | 08:19 PM
LQ4 S10's Avatar
Default first time turbo
what a/r should i get for 5.3 also would stock cam work good or should i get different one i will be using mp t70 turbo also what size injector should i use looking for 500rwhp maybe a lil more
Old Jan 25, 2011 | 12:12 AM
2XR95Z28's Avatar
stock cam would work but a budget upgrade would be an 02+ z06 cam that can be found cheap used on vette forums. Best ar would be a .96 on the mp t70 and 60lb injectors from poweraddersolutions.com are a good value and would work for your needs. I have all these and in my last setup i was able to go 7.0 in the 1/8th on around 6-8 pounds.
Old Jan 26, 2011 | 06:30 PM
LQ4 S10's Avatar
can i use stock fuel regulator
Old Jan 26, 2011 | 11:30 PM
2XR95Z28's Avatar
i personally wouldnt, i would look into a cheap aeromotive regulator with a boost reference on it. always better to be safe than sorry...
Old Jan 27, 2011 | 05:54 AM
LQ4 S10's Avatar
would i need new fuel rails since stock one is on it
