Merge pipe- will this work, or?
Old Jan 31, 2011 | 08:25 PM
Hwystar's Avatar
Default Merge pipe- will this work, or?
This is the factory y-pipe, that I cutup just to see if it would work. What do you think, use it or make a different one?
Old Jan 31, 2011 | 08:59 PM
Ryans99ls1's Avatar
it will work but you could probably make a better merge too
Old Jan 31, 2011 | 09:03 PM
Hwystar's Avatar
Thats what I'm thinking, but this sure has a good flat area for the wastegate.
Old Feb 1, 2011 | 01:32 AM
Fondle's Avatar
i used an identical one on my v6 turbo build, worked fine for me and still pulled like a train.
could it be made better? sure, but its not needed, i doubt you will loose any power with a merge like that
