any trick to building a/w intercooler
Old Feb 15, 2011 | 04:19 PM
Fireball's Avatar
those look like whats available off-the-shelf...why bother building one?
you can find those style A2w used all the time at very low prices.
Old Feb 15, 2011 | 05:07 PM
MIGHTYMOUSE's Avatar
they all do look similar, but unfortunately looking similar and having the dimensions i need is not the same.
Old Feb 15, 2011 | 10:09 PM
Snyper's Avatar
What are you doing with your old one? And what are the size specs on it?
Old Feb 15, 2011 | 11:02 PM
Josh@KY-Turbo's Avatar
You have an Solid Works models of an LS1 Engine on Hand?
Old Feb 16, 2011 | 01:23 AM
Billy the Great's Avatar
looks badass, did you use the sheetmetal tools? it looks like it in the last pic.
i have been trying to find any kind of 3d cad model of the ls engine, to no avail. only lead i have found so far is i guess if you are a member of SEMA then you can get a copy. Jim Schwartz from schwartz performance has it, he shows it in one of his youtube videos.
Old Feb 16, 2011 | 06:20 AM
Snyper. Provided the old one gets reeplaced ill be selling it eventually. Its a cast end tank pt-900
Josh, I have an e-derawing of an Ls1 set up for C5.
Billy, yea first I made the solid (yellow) to determine the shape quickly then I made the sheet metal parts to match it. I flatten those and send straight to the laser here at work.
Old Feb 16, 2011 | 10:05 AM
Sending PM.
Old Feb 16, 2011 | 10:13 AM
Originally Posted by Josh@KY-Turbo
Sending PM.
x2...
Old Feb 17, 2011 | 06:03 AM
Bobsmyuncle's Avatar
if u are used to tigging aluminum, you can build one, biggest part is having leak free welds, and put some support straps on that thing to keep it from turning into a bomb. remember PSI=pressure per square inch. an intercooler the size ur lookin could have over 100 square inches, at 20 psi, thts 2k lbs of force on that thing. thats why they make blankets for em just like trannys, they turn into shrapnel lol
Old Feb 17, 2011 | 06:45 AM
crap forgot to send images from the flow simulation home..
Old Feb 17, 2011 | 07:28 AM
chuntington101's Avatar
MIGHTYMOUSE, hwere are you planning on mounting the new chargecooler? Same spot as with the TTI?
Thanks,
Chris.
Old Feb 17, 2011 | 11:50 AM
  #32
Yes bolt in same place and allign to existing water and air tubes
Old Feb 18, 2011 | 02:19 PM
  #33
99.9percenter's Avatar
Make sure all the oxidation is off and dont let it get too hot
Old Feb 18, 2011 | 04:46 PM
  #34
some potentially interesting flow simulations images
first one is more curved end tank, second is a straight diagonal and third is the same as the first but with a divider that forces half of the flow to the front half of the intercooler
Attached Thumbnails any trick to building a/w intercooler-flow1.jpg   any trick to building a/w intercooler-flow2.jpg   any trick to building a/w intercooler-flow4.jpg
Old Feb 18, 2011 | 06:46 PM
  #35
Sluggish's Avatar
Less velocity equals greater pressure drop?
Old Feb 19, 2011 | 03:41 AM
  #36
stevieturbo's Avatar
With such a tiny core and generally a small unit, internal ducting is essential.
Old Feb 19, 2011 | 09:56 AM
  #37
93formto98T/A's Avatar
What dimensions are you going for? Those look very similar to the one I'm running. Rated at 1600hp.
Attached Thumbnails any trick to building a/w intercooler-rx7wb-023.jpg   any trick to building a/w intercooler-13.jpg
Old Feb 19, 2011 | 06:13 PM
  #38
air tubes are 14" center to center.
who makes that one?
Old Feb 20, 2011 | 05:38 PM
  #39
who makes that one?
Mine is 19" total width which would put the tube centers at around 16". Had this one made by Marty at IRC fabrications.
