supercharger belts? HELP!!!!
Old Feb 19, 2011 | 05:21 PM
1toofastlt1's Avatar
Default supercharger belts? HELP!!!!
Hey im trying to set up my blower but I cant seem to find the right size belt. I have a vortech V1 on my 97 camaro. Im running a 7.8 inch crank pulley and a 3.33 supercharger pulley. I NEED a 45 inch 8 rib belt and I can't seem to find one. Any help would be great.
Old Feb 19, 2011 | 06:06 PM
Pocket's Avatar
http://www.goodyearep.com/ProductsDetail.aspx?id=3128
Lots in there
How you read a belt PN:
STD
Class Ribs Length in inches to one decimal
406923
40 pass car series, 6 ribs, 92.3" long
Metric
Ribs Class Length in mm
6PK2345
6 ribs, pass car series, 2345mm long
Practically all belt mfrs use one/both of those naming systems
Old Feb 19, 2011 | 06:07 PM
phatasp's Avatar
Napa is where I get my belts. I have about 9 or 10 belts I,ll check them when I get home and see if they,ll do you any good.
Old Feb 19, 2011 | 11:14 PM
ok cool let me know. Thanks for the help
Old Feb 20, 2011 | 02:34 AM
phatasp's Avatar
The shortest belt I have is 48.5 but I found this on the napa website
Belt - Serpentine
Product Line: NAPA Belts & Hoses
Part Number: NBH 25080450
Price: Price
Unit
29.99
Each
Features & Benefits For Replacing Original Belts On Serpentine Drives & Other V-Ribbed Applications. Designed For Small Dia. Pulleys, Backside Idlers & Use w/ Or w/o Automatic Tensioners. Unique Form Grinding Of Each Individual Belt Assures Precise Dimensional Control.; Special Belt Constructions Eliminate Belt Noise, Reduce Tension Loss & Solve Problem Drive Applications. Specially Constructed To Resist Wear & Cracking. Special Tensile Members & Fiber-Loaded Reinforcement Of Ribs For Added Wear & Crack Resistance.; Meets Or Exceeds SAE J1459 Specifications. Also Known As Micro-V Belts.
Attributes # Serpentine Belt Ribs : 8
Belt Angle : 40 Deg
Outside Circumference (in) : 45.685"
Outside Circumference (mm) : 1160 mm
Section : K
Top Width (in) : 1.087"
Top Width (mm) : 28 mm
I hope this helps
Old Feb 20, 2011 | 10:23 AM
Kory 88Iroc Lt1's Avatar
I was looking for this info.
Thaks for posting.
Kory
Old Feb 22, 2011 | 12:59 AM
Belt - Serpentine
Price: Price
Unit
29.99
Each
Belt Angle : 40 Deg
Section : K
I hope this helps
Awesome man. I just ordered this belt today. Thanks for the help
