vortech sc help
Old Feb 25, 2011 | 03:58 PM
redws618's Avatar
Default vortech sc help
a buddy of mine has a v2 or v3 sci supercharger on his 5.3, im interested in buying it but would it be okay on my ls1? is there anything i would need?
thanks.
Old Feb 25, 2011 | 04:54 PM
LSpeed1's Avatar
thanks.
what kind of headunit?
is it an ls1 kit?
Old Feb 25, 2011 | 04:59 PM
TheLS1Lover's Avatar
IS the headunit Counter Clockwise? The head unti will work if so.
You will need
-Bracket
-Oil Drain and Feed Lines (If it is the V2, V3 is self contained)
-Charge Piping
-or a Front Mount Intercooler, Vortech's Aftercooler would also work but FMIC is cheaper.
-A Tune
-New Injectors
-Fuel Pump
-Mass Airflow Meter, not needed with a Speed Density tune.
-and a Intake of some sort
That should cover the major things.
Old Feb 25, 2011 | 09:33 PM
redws618's Avatar
You will need
-Bracket
-Charge Piping
-A Tune
-New Injectors
-Fuel Pump
He has an intercooler that'll come with it, tune is not an issue. I have a 255 pump with 42lb injectors. I have an sd tune already. It is a v2 for a 2006 truck. I'm thinking the only thing that will work is the actual supercharger. Correct me if I'm wrong please.
Old Feb 26, 2011 | 11:02 PM
LSpeed1's Avatar
si trim? t trim?
and rotation all matter. you could give rmcr a call as they still deal with vortech units on ls1 f bodies.
Old Feb 27, 2011 | 10:36 PM
redws618's Avatar
Originally Posted by LSpeed1
si trim? t trim?
It's a v2 si.
Old Apr 27, 2012 | 11:49 PM
Bradlyj8Z28's Avatar
I found a similar deal, did you end up doing it?
