600RWHP Maggied LS2 GTO
Old Feb 26, 2011 | 02:37 PM
LSWONGTO's Avatar
Default 600RWHP Maggied LS2 GTO
Engine Stock Bottom End LS2
Trans RPM Stage 4 T56 & a RPS Twin Disc
Blower Maggie 122HH
Pulley Setup 3.0 upper , 1:1 rears , Stock 7.25 crankpulley
Cooling Setup LFP 03/04 Cobra Dual Pass H/E , Moroso Battery Tray tank for 05-09 Mustang , Maggie coolant pump
Heads Trickflow 225 cnc 65 cc cambers / GM Headgaskets
Fuel Maggie 60lb Injectors , Lingenfelter/Walboro 255 Pump
Cam is a TSP TQ V.2 232/234 .595/.598 113LSA
Exhaust Kooks 1 3/4th headers, catless mids , Bassani CB
Intake Volant Box , ported LS2 TB
Tune Uber Conservative 2 Bar SD tune by Andrew @ CSP
= I lied, best pull was 597/533
Attached Thumbnails 600RWHP Maggied LS2 GTO-122-20dyno0001.jpg   600RWHP Maggied LS2 GTO-maggie-203.jpg   600RWHP Maggied LS2 GTO-maggie-20side.jpg   600RWHP Maggied LS2 GTO-heat-20exchanger-20goat.jpg
Old Feb 26, 2011 | 02:38 PM
LSWONGTO's Avatar
http://www.youtube.com/watch?v=tz9NK...layer_embedded
Old Feb 26, 2011 | 06:29 PM
S2VYSS's Avatar
Great power output and love the blower whinge!
Is the gauge moulded into the speedo cluster custom or an off the shelf item?
Old Feb 26, 2011 | 07:42 PM
madmax4499's Avatar
looks and sounds great, what boost are you showing? i like the nice flat Tq, curve
Old Feb 26, 2011 | 07:50 PM
Photochop's Avatar
Excellent numbers for 8psi, I bet it's a blast to drive. Time for some tires!
Old Feb 27, 2011 | 03:36 PM
LSWONGTO's Avatar
Its custom made by a LS1GTO.com forum sponsor (Maverick Man). Thanks its the tq makes it 100 times more to drive vs when it was just Heads/Cam. I put her on the scale with a full tank she is at 3600lbs now.
LSWONGTO's Avatar
Thanks, its at 8lbs
Old Feb 27, 2011 | 03:37 PM
LSWONGTO's Avatar
Yes.. I haz no traction..
