Boost and vacuum operated gauges
Old Feb 27, 2011 | 11:25 PM
Monte4ever's Avatar
Default Boost and vacuum operated gauges
Question; what happens to the stock vacuum operated gauges when a turbo or supercharger is added. Do you have to add a check valve to protect the gauges from boost or will they be alright?
Old Feb 28, 2011 | 12:20 PM
black98ws6ta's Avatar
What gauges are you speaking of? F-bodies have factory check valves on the brake booster and the signal line that runs into the cabin for the hvac door actuation.
Old Feb 28, 2011 | 06:52 PM
Monte4ever's Avatar
This is for a 82 Monte Carlo and I'm mostly talking about the small diameter nylon lines to and from the heater control unit.
Old Feb 28, 2011 | 07:25 PM
I would go ahead and add a check valve to prevent any damage.
