Have questions for boost
Old Feb 28, 2011 | 08:19 PM
drknitterbros's Avatar
Default Have questions for boost
I have a 98 ls1 camaro that I have upgraded to 99 ecu and everything with level 3 4l60e for boost have all hot and cold side for rear mount set up with t-70 now I know I need wastegate,bov,oil pump and lines and intercooler with pipes but my question is can I put it on and tune with stock fuel pump,injectors,and springs if so what psi can I put it at? was only thinking of running 5lbs till i get the above listed let me know what I can do thanx
Old Feb 28, 2011 | 08:32 PM
ttranssam's Avatar
you can install it and roughly tune it but id just wait! you NEED springs and pump(s)
Old Feb 28, 2011 | 08:33 PM
20TA02's Avatar
with my T67, i maxed out my fuel with a walbro 255 and a hotwire kit so i had to add another pump and that was at 6# of boost. once i added the other pump i went with 60# injectors as well...
ive seen the sts kits handle with the stock fuel stuff... but then again, youre running a T70...id just wait it out and get everything together and slap it all at once. (just my .02)
Old Feb 28, 2011 | 10:36 PM
A buddy of mine had a t-67 on his and had a walboro 255 and springs with 42lb injectors and that was it the rest stock but was pushing 10lbs so was hoping I could get away with 3-5lbs without getting the fuel stuff but ok I'll wait it out thanks
Old Feb 28, 2011 | 10:57 PM
20TA02's Avatar
cool... take pictures of it as you build it...
Old Mar 5, 2011 | 03:10 AM
Also I know I need a walboro pump and heard that it can't be used in a 98 gas tank is this true and also what springs should I use and which injectors are recomended was going to get 42lb
