turbo exhaust routing
Old Mar 1, 2011 | 10:56 PM
FL Junkie's Avatar
Default turbo exhaust routing
when you build the hotside going to your turbo how does the exhaust exit? how would you route it thru a muffler and where do u mount the muffler? i read the sticky about how to fab it up with the truck manifolds, but it didnt show where the exhaust goes out.
can somebody post pics of their turbo exhaust to give me an idea?
Old Mar 2, 2011 | 11:00 AM
FL Junkie's Avatar
anybody have pics?
Old Mar 2, 2011 | 12:16 PM
lifeisgood's Avatar
The reason no one is replying is there's a search button. Use that. There's millions of pics on this forum. And you can route your exhaust anyway you want.
Old Mar 2, 2011 | 12:29 PM
FL Junkie's Avatar
i know theres a search button i use it quite often. i cant find a pic of what i was looking for. theres pics of the turbos and hotside but not one of the exhaust routing. im looking how its routed from the front in particular.
Old Mar 2, 2011 | 12:34 PM
Ryans99ls1's Avatar
most people run the downpipe between the motor mount and block on the passenger side, this is assuming you built a kit that required deleting the A/C. Then just follow the path of a normal ypipe.. I mean technically you could even use your old ypipe you would just have to get rid of the drivers side pipe..
Old Mar 2, 2011 | 01:33 PM
98Z28CobraKiller's Avatar
Restricted User
Old Mar 3, 2011 | 11:14 PM
RCHipps21's Avatar
Before you attempt this I believe you will only be able to fit a 4" DP through there with a BMR Turbo K Member.
