Reason to solid roller ? For a higher revving motor
Old Mar 2, 2011 | 05:25 AM
BigRich954RR's Avatar
Default Reason to solid roller ? For a higher revving motor
Trying to build a smaller ci engine. But
Rev it Out higher for a longer amount of time. A solid roller cam should be easier on the valves and springs cause the lifter are lighter right? Will they also lessen how much oil gets pumped to the valve covers on long high Rpm pulls?
Old Mar 2, 2011 | 06:57 AM
cjmatt's Avatar
I cant speak on the oiling issue, but a solid roller offers higher stability at higher rpms. The hydraulic lifters work off the basis that they pump up with oil so that they take the play out of the valvetrain. You will have to check the preload on your rockers frequently with solid roller lifters.
Old Mar 2, 2011 | 07:15 AM
frequently i knew this but a guess how many races ? or street miles you think ?
i went with hyd and after some issues and thoughts thinking i should have went solid.
how much more rpm can you get out of a solid ?
what rockers will i have to run now? i have TFS 245 heads ?
how high would you spin a solid roller with a 3.8 stroke crank, with turbos ?
Old Mar 2, 2011 | 07:17 AM
Shawn @ VA Speed's Avatar
solid rollers allow you to use much higher spring rates for better valve control with higher lift and more agressive lobe profiles. Most soild rollers do restrict the oil in the lifter so not as much oil travels to the top of the engine. you can only run high rpm if your turbo or sc has enough airflow to allow it to run higher rpms.
Old Mar 2, 2011 | 07:21 AM
this is very much a false statement. if the valvetrain is setup properly lash adjustment should only have to be done one a season on racecars, and maybe twice a year on street cars. if the lash changes-something is wearing,enough wear to change lash very much and you have an issue. you need to remember most imports have solid valvetrains and very,very seldom need adjustment
Old Mar 2, 2011 | 07:35 AM
Shawn. im really thinking ill just have to have you build my motor cause there a bunch of things i want to change. plus im getting a bunch of intake reversion which is really making my intake ports get dirty.
im not to worried about more aggressive lobe profile. i only want a little more power but, a better motor over all
Old Mar 2, 2011 | 09:53 AM
cjmatt's Avatar
Twice a year is often to me! lol
