sugestions
Old Mar 6, 2011 | 04:30 AM
drknitterbros's Avatar
Default sugestions
I'm about to boost my 98 z28 and am collecting the final pieces for my rear mount set up just wondering what springs,injectors,and fuel pump would be recomended? Was thinking patriot duals with 42lb injectors with a walboro 255...also heard that the fuel pump I want won't work in my 98 tank is this true? And what would be the limit of psi on my stock motor will apreciate any input thanks
Old Mar 6, 2011 | 07:44 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The Patriot Gold pn# 8401 valvespring kit is a good way to go.
You could get by with 42lb injectors, but unless you can find a killer deal on them, I'd go with 60lb injectors. 60lb injectors give you the option down the road to be able to add more power to your combination without running out of fuel, as soon as you would with 42lb injectors.
A Walbro 255 works just fine in your steel tank. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Mar 7, 2011 | 02:25 AM
Ok cuz the guy that does all of my tuning and most work on my car said the walboro woudnt work in my tank yet he installed 1 in a buddy of mines 95 lt1 with the same tank but had another question I switched to a 99 cpu and everything do I need to get a 99+ fuel sending unit cuz my gas gauge no longer works
