which iat
Old Mar 8, 2011 | 07:24 PM
LQ4 S10's Avatar
Default which iat
what sensor do i need to work with stock 99 5.3 ecm since not running maf need to know which sensor i need
Old Mar 8, 2011 | 07:28 PM
Orangemagic's Avatar
Depends on how you want to mount it. You can run a 92 or so typhoon one that threads in 3/8 npt with same plug in. or your can run a 98-02 f-body one. I'm sure there are plenty more options.
Old Mar 8, 2011 | 07:29 PM
robbyredneck's Avatar
i got the stock 00 camaro iat and a toyota pcv grommet for my turbo build
Old Mar 8, 2011 | 08:47 PM
LQ4 S10's Avatar
didnt know if they where different because mine is in the maf so will have to get pigtail for it too
Old Mar 9, 2011 | 12:22 AM
XtremeDime's Avatar
Use the screw in type that the Sy/Ty's have. Itll plug right into the harness and read fine. Im still using my stock one with grommet and some RTV.
Old Mar 9, 2011 | 09:22 AM
your gonna need the pigtail. i went to the yard with my iat and got one off a park ave or some thing. just take the sensor with you and get a clean one. i too have the rubber grommy and rtv.
Old Mar 9, 2011 | 06:45 PM
LQ4 S10's Avatar
thanks
