Fml!
Old Mar 12, 2011 | 12:43 AM
wilson34's Avatar
Thanks Mrs. 3rd grade teacher, I thought you would be busy grading our punctuation tests
Old Mar 12, 2011 | 05:54 AM
lifeisgood's Avatar
Haha, it'll buff out.
Let people judge, they don't have anything better to do.
Is everything wrote in correct fashion?
Old Mar 12, 2011 | 10:47 AM
TermnEatr's Avatar
Originally Posted by WhistlingZ
Cool. Send me a link to that other motor :-D
when I get my motor back I will send you a telephone number for that motor. Not sure if he wants to ship it though.
Old Mar 13, 2011 | 08:50 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by lifeisgood
i believe the tap is hardend and the old lt1 bolts arent? am i wrong?
if im right its not the easiest to drill and remove
but a good machine shop like everyone says could do it alot cheaper than buying a new block
There's ways for the DIYer to get something like this out in the garage. Just takes a little work and patience.
Old Mar 13, 2011 | 10:26 PM
madmax4499's Avatar
Then why dont you tell him how to do it. have you ever tried to drill a tap, at an angle. that stuff is so hard you cant even center punch it. even a super hard cobalt bit will burn up on a tap. how much of the tap broke off in the hole, if it is not to thick you might be able to crack it and pull it out in pieces. let us know what you come up with.
Old Mar 13, 2011 | 11:44 PM
lunati397's Avatar
drill it tap it and insert a helicoil they are good enough for a 35000lb helicopter to hang from 8 bolts to a gearbox id say they can handle a head
Old Mar 14, 2011 | 09:05 AM
slow67's Avatar
Gingervitis Addict
X2. Just make sure you drill th hole straight.
Old Mar 14, 2011 | 09:47 AM
lifeisgood's Avatar
i still vote for machine shop and helicoil.
if they **** it up they buy new block, you **** up and you buy new block
Old Mar 14, 2011 | 03:56 PM
OWN3D BY MY PROF!
Cut the ends off of a pushrod, inset in hole, drill away. It'll guard the threads as you drill.
Old Apr 3, 2011 | 12:57 PM
TermnEatr's Avatar
motors still at the shop there super busy since our strip opens next weekend. Ill stay posted when i get some news.
Old Apr 3, 2011 | 07:12 PM
ta02zx10r's Avatar
did you try a lefthand drill bit?
Old May 5, 2011 | 10:54 AM
  #32
TermnEatr's Avatar
going to pick up my block today! Kinda hit the pocket book chargin me 400 bucks but it's worth it and plus they had to order some custom drill bits and burned through two of them lol arp makes some hard ****.
Old May 6, 2011 | 12:55 PM
  #33
charleysheen's Avatar
theyre lying to you...how hard could it have been if you broke it with your hand?
Old May 6, 2011 | 01:21 PM
  #34
kmracer's Avatar
i hope you paid them to chase the other threads too...
Old May 6, 2011 | 02:08 PM
  #35
pwrtrip75's Avatar
$400. ?? Holy ****~!! What did they do file it out with dental tools ... from the inside?
That seems kinda high.... they got you by the ***** though....what can ya do.
Old May 6, 2011 | 02:11 PM
  #36
XXX37's Avatar
they make special tools specifically for removing broken taps. it has fingers that slide down into the flutes of the tap, then a sleeve that slides down and hold the fingers together.
Old May 7, 2011 | 09:03 AM
  #37
TermnEatr's Avatar
ya I seen them tool couldn't find one long enough to get down to the tap
