Video of us testing out the transbrake!
Old Mar 20, 2011 | 03:13 PM
mr_biscuitz's Avatar
First try my FTI conv would make 10lbs on the brake, sent it back in and then it made 6-8lbs, now sending it back again to hold the power up top.
Old Mar 20, 2011 | 03:36 PM
Sideways240sx's Avatar
Well my boost controller is set to about 9 or 10 psi, so it might make more still!
Im guessing the car will spin with the old converter we got about 4 psi and cut a 1.37 60, so i will be using a 2 step along with it
Thanks chris
Old Mar 20, 2011 | 03:51 PM
98Z28CobraKiller's Avatar
Restricted User
Originally Posted by Sideways240sx
How do you think it will work compared to a vic jr, or stock ls6 style intake?
Thanks, Chris
In most FI applications, I'd take the Pro Flo XT over any other "off the shelf" intake. I would ditch my ported FAST90 in a second if I could fit it without cutting my **** all up.
Old Mar 20, 2011 | 03:56 PM
Restricted User
Thanks chris
What he is saying is that the converter is making boost because it is too loose. If you took that converter to the track, you'll find that you will blow right threw it up top and have poor MPH. As they tighten them up, it'll be harder to build boost but will work much better out the back.
Old Mar 20, 2011 | 04:26 PM
van383's Avatar
Patriot 317's. I will be re dynoing the car soon, but i also changed to a new converter, in guessing that will affect the numbers as well. Do you run a pro flo now? Are you not happy with the results?
no i run a vic jr port matched now, but my porter seems to think a sheet metal style will gain me some power over what i have.. last year at 3250lb and 317 heads and 370 cube on 20 psi car went 5.54 at 128. swaped to bigger 235 head now, thats why i was wondering about it..
Old Mar 20, 2011 | 05:57 PM
LASTLS1's Avatar
6 Second Club Moderator
I dont really see any harm done. Trans temps never got hot, motor didn't get hot. I have a big trans cooler, with a fan on it.
Chris
Don't worry about it. Some poeple don't have a clue, that's how you test it. I've done it MANY times.
Old Mar 20, 2011 | 07:12 PM
Thanks. I know that is the proper way to do it in the pits, and i have seen it done. Your not supposed to do it on the ground in case it lets go.
Thanks chris
Old Mar 21, 2011 | 09:31 AM
LASTLS1's Avatar
Thanks chris
I hold the foot brake pretty hard and make sure I have clear space in front of me. If the pits are too tight I'll go to a open area.
Old Mar 21, 2011 | 11:30 AM
Restricted User
Agreed. Tbrake/2 step timing and fueling should be tested and correct before you get to the line.
Old Mar 21, 2011 | 12:57 PM
TracyRR's Avatar
It comes up quick!! Very nice build, congrats
Old Mar 21, 2011 | 01:17 PM
0269camaro's Avatar
Not much sounds cooler than a turbo on the brake.
Old Mar 21, 2011 | 02:53 PM
  #32
Broke EF's Avatar
It should sound better with the two step thrown in there as well
Sean
Old Mar 22, 2011 | 02:51 AM
  #33
Wicked94Z's Avatar
Chris
you have a temp sender in your converter?
Originally Posted by rmata
That car looks sick. I think what that one guy meant is that it's not a good idea to get on the trans brake and then let off the gas to bring it back to idle. I'm no trans expert and wouldn't be able to tell you the harm it can cause or if it's even true or not, but it's just always been my understanding that when you engage the transbrake you need to launch it
exactly, its hard on the stator in the converter, that's not speculation that's fact. Plus you're cooking the fluid in the converter, I don't care what you THINK the fluid temp is in the cooler or return line, it's a lot higher in the converter.
Originally Posted by Taubr Unit
im sure that converter/trans will be JUST fine for those 10 seconds...some people i tell ya, lol
see above, maybe my original post was a little harsh, but it's still not good practice
And you're the guy who "has a clue" and tests his transbrake in the pits with his car on the ground
Old Mar 22, 2011 | 08:13 AM
  #34
Restricted User
So what's the difference between doing it in the pits vs on the line? I mean with the exception of all the spectators.
Old Mar 22, 2011 | 08:58 AM
  #35
rotary1307cc's Avatar
lol seriously?
you do realize how long some setups have to sit on the converter to spool right? look at some pulling truck vids with large singles once.....
Old Mar 22, 2011 | 09:20 AM
  #36
LASTLS1's Avatar
Nothing. I've done it for years. I've never had a tans or converter fail and I check it every race day. Just jinxed myself, lol. To each his own, I wouldn't check it with anybody or thing in front of the car (obviously). I drive my car around the track to warm everything up and test it then. I would love to hear how you check it without using it.
Old Mar 22, 2011 | 10:43 AM
  #37
Broke EF's Avatar
Like I said, if that makes something fail we have bigger problems.
Sean
