beating the horse, looking for rec's on ebc's
Old Mar 19, 2011 | 02:56 AM
2004SSS's Avatar
Default beating the horse, looking for rec's on ebc's
ben trying to figure out which controller is best suited for me. not a crazy setup but need some help bringing the boost in
application is
Silverado SS , AWD, 427 lsx with twin gt-35's . running twin 44 wg's.
having some issue's now with overboosting, running 10 psi springs in the gates and im seeing near 15 psi @ wot. doesent bother me but keeping traction even with awd is not easy. id like something that will ramp the boost as it comes in to help traction or comes in low boost in 1st gear and then high throughout the run , or a timed ramp rate.
the two controllers i had been eyeing were the eboost2 and the ams-500 .
i like simple and something easy to adjust and setup . i know some will default if it cant acheive target boost. i like that but id like to be able to set it and it not default if possible.
i have room for either and could run the c02 setup as long as its not overly complicated and bulky.
any help is appreciated
wouldn also like to see a c02 setup with either if possible.
