LQ Toyota Build
Old Mar 23, 2011 | 03:09 PM
rhinosarge's Avatar
Default LQ Toyota Build
so .. please .. not all at once. i know theres a millions questions.. but i have a million questions of my own to ask ALL YOU TURBO GURU'S
2005 LQ4 off hd2500
ARP STUDS <NEW
YELLOW SPRINGS <NEW
Z06 CAM <NEW
MOTOTRON 60lb <NEW ---> WHAT CONNECTORS DO I NEED? EV6 TO EV1?
2008 TRAILBLAZER MANIFOLD
BBK 80MM CABLE TB
EBAY INTERCOOLER
38MM TIAL WASTEGATE W/ 8LB SPRING
38MM HKS BOV
my harness was custom made.. no MAF, no rear o2's.. no park neutral safety .. runs off speed density and IAT sensors.. (mind went blank)
oil pan has a new plug welded to the front cause off install cant reach stock location
turbo is a small turbo .68 hot side from the STS 6.0 gto kit.. i dont need a huge turbo since ill be in the sand a lot!!!
dont need a stall either for that same point...
3IN CUT OUT .. I HAVE A AEM WIDEBAND AS WELL
need to figure out how to run intercooler pipes.. oil supply.. radiator & fans..
and install the b&m shifter to the 4l60e
here some pics.. enjoy.. its not installed yet..
older pics
Old Mar 23, 2011 | 03:39 PM
My2kz28's Avatar
damn son!!! Id like to see a vid of you jumping that thing!
Old Mar 23, 2011 | 05:25 PM
rhinosarge's Avatar
soon!! i need to finish this !! like this month.. i wanna go out test in april..
memorial weekend at pismo beach, ca
Old Mar 23, 2011 | 05:36 PM
My2kz28's Avatar
For sure i used to live in riverside and went to pismo all the time..hot babes for days...show them your truck then get some!!
Old Apr 2, 2011 | 06:17 AM
rhinosarge's Avatar
what sparkplugs to run?
Old Apr 4, 2011 | 05:11 AM
kmracer's Avatar
tr6's or tr7's should be fine
