Oil for FI
Old Mar 28, 2011 | 08:19 PM
ASkipper's Avatar
Default Oil for FI
What kind of oil do you guys with Turbo/ Supercharger use. I have heard that synthetic is a no no. What would be good to use if I decide to go turbo.
Old Mar 28, 2011 | 08:38 PM
tomz28's Avatar
ive been running mobil 1 10w30 but i have a hi-pressure/hi-volume pump
Old Mar 28, 2011 | 09:20 PM
93formto98T/A's Avatar
Synthetic is a yes yes with FI. It functions well at high temps (seen in FI engines/turbos) whereas dino does not. Most any name brand 10w-40 full synthetic will do the job on a mild build.
Old Mar 28, 2011 | 10:14 PM
XtremeDime's Avatar
I used the 10$ a jug oil from Walmart last year. Never had any problems but I also changed my oil every 500 miles or so it seemed.
Old Mar 28, 2011 | 10:15 PM
rotary1307cc's Avatar
I use Schaeffer synthetic
Old Mar 29, 2011 | 12:27 AM
revtech101's Avatar
Use synthetic motor oil. They usually have a higher boiling temperature compared to conventional motor oil.
Old Mar 29, 2011 | 12:32 AM
The Beast's Avatar
Rotella 15-40 dino oil
Old Mar 29, 2011 | 12:36 AM
fatmat80's Avatar
VR1 straight 30 here
Old Mar 29, 2011 | 11:18 AM
Orangemagic's Avatar
I'm using the same oil in 10w 30 now. I will be switching to their race oil 20w-50 as soon as the warmer weather comes.
Old Mar 29, 2011 | 11:39 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I use Valvoline racing VV850 (10W30). Has tons of ZDDP. So much in fact that its not street legal since it would totally destroy catalytic converters.
Old Mar 29, 2011 | 12:39 PM
cjmatt's Avatar
Whats a catalytic converter? lol
Old Mar 29, 2011 | 12:47 PM
kkslds's Avatar
I use Brad Penn 30w... 16 psi on my bone stock longblock and still ticking
Old Mar 29, 2011 | 01:12 PM
ChevyChad's Avatar
An attempt made by the man to hold you down
Old Mar 29, 2011 | 01:20 PM
FMX05's Avatar
Don't worry, they all do that.
Old Mar 29, 2011 | 01:57 PM
CarsandWomen's Avatar
I lol'd twice in a row
Chad, care to elaborate on ZDDP?
Old Mar 29, 2011 | 07:16 PM
Tally TransAm's Avatar
Old Mar 29, 2011 | 07:54 PM
ChevyChad's Avatar
Basically, ZDDP is a super lubricant thats far better than the rest of the ingredients in oil. Most oil has a tiny bit of it, but the government has mandated that oils can only have so much since it harms the catalytic converters and shortens the life of them. There is a ton of information about ZDDP out there, this is just the tip of the iceberg, but thats the gist of it.
Old Mar 29, 2011 | 10:29 PM
Adam86's Avatar
Check out bobistheoilguy for great info on ZDDP. Bottom line is you want a LOT of it if you're not running cats.
Old Mar 29, 2011 | 10:32 PM
ChevyChad's Avatar
Old Mar 29, 2011 | 10:57 PM
KILLER-LS1's Avatar
Torco 10-40 SR1 here. Lots of Zinc in it (ZDDP)
