Cam change based on heads?
Old Mar 31, 2011 | 07:54 AM
s-cam's Avatar
Default Cam change based on heads?
I have a 416ci LS3 with et performance cathedral port heads, a 122 supercharger and a custom ground flow tech cam. its been a great combination but have decided to upgrade to a tvs 2300 and ls3 style heads ( either scoggin dickey cnc ls3 or WCCH lsa heads) If i could have made the supercharger work on the old combination i would not be changing the heads or cam.....
What i am wondering is will the camshaft that was ground for the et performance cathedral port heads and a supercharger work or does the cam grind change drastically when LS3 style heads are installed. If the existing cam will work well then no sense in changing it but if i am sacrificing drivability or Hp or TQ then now is the time to order a new one.
Simply put- does the cam profile need to be changed when changing from cathedral port heads to square port heads?
Thoughts?
Old Mar 31, 2011 | 08:19 AM
dschmittie1's Avatar
Not saying your current cam wouldn't work well in the car but I think a cam that is designed for the heads you are putting on would be more efficent. I know Comp list many different cams based on what style head you have as they flow very different from older catherdral port stuff
Old Mar 31, 2011 | 01:09 PM
lt1773's Avatar
not telling the specs of the cam will cause no benefit
Old Mar 31, 2011 | 09:32 PM
s-cam's Avatar
These are the specs i have on the cam.
Lobe Lift: .360” .360”
Gross Valve Lift 1.70 Ratio: .612” .612”
Duration @ .050” Tappet Lift: 230* 240*
Lobe Separation: 116*
Recommended Intake Centerline: 113*
Specs at 113 Degree Intake Centerline:
Valve Timing at Open Close
.050” Tappet Lift: Intake: 2* BTDC 48* ABDC
Exhaust: 59* BBDC 1* ATDC
