T4 Turbo inlet pipe size
Old Apr 6, 2011 | 09:48 AM
Bowtie316's Avatar
Default T4 Turbo inlet pipe size
Okay, I am starting to fab my hot side from stock manifolds to a T4 turbo flange. I would like to merge the 2 pipes before the turbo (for packaging reasons) and run a single pipe from the merge about 1 foot to the turbo flange, is it okay to do it this way?
Also, what size should the pipe be? Measuring the circumference of the t4 inlet hole would equal about a 2.5" od exhaust pipe, will 2.5 be sufficient?
Thanks for any help.
Old Apr 6, 2011 | 09:58 AM
Phil99vette's Avatar
7 Second Club
Will work awesome, use a nice merge from cone engineering.
Old Apr 6, 2011 | 11:29 AM
JAX04's Avatar
+1 great products!
Old Apr 6, 2011 | 11:39 AM
Bowtie316's Avatar
I had planned to build something similar to this.http://www.hotrod.com/techarticles/e.../photo_11.html
Then just slip my 2.5 pipe over the end, mark it, and cut off enough to butt weld it.
Old Apr 6, 2011 | 12:48 PM
7 Second Club
That will certainly work just more labor.
Old Apr 7, 2011 | 07:09 AM
Bowtie316's Avatar
Thanks for the help, this is an awesome forum.
