vacuum switch?
Old Apr 10, 2011 | 01:29 PM
pdasterly's Avatar
Default vacuum switch?
whats a good reliable switch to operate my secondary fuel pump and meth injection?
Old Apr 10, 2011 | 01:39 PM
willizm's Avatar
I'm guessing you are referring to a vacuum manifold right? If so give this a look. I picked it up so I wouldn't have to daisy chain a bunch of t's. Still building the car up so haven't used it yet, but it comes with extra plugs and junk.
http://cgi.ebay.com/ebaymotors/BLOX-...#ht_2491wt_722
Old Apr 10, 2011 | 01:58 PM
pdasterly's Avatar
I actually have that same manifold and my bbk intake has a extra port in the rear so im going to use that. What I mean by vacuum switch like hobbs switch
Old Apr 10, 2011 | 02:32 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I've been running a switch similar to this one on my car for many years with no issues
http://cgi.ebay.com/ebaymotors/ws/eB...%3D1&viewitem=
Old Apr 10, 2011 | 07:46 PM
LS1NOVA's Avatar
You can get a Hobbs switch at your local parts store. Mine activates my second fuel pump at 4psi.
Old Apr 11, 2011 | 12:35 PM
FastKat's Avatar
If you're looking for a vacuum operated switch rather than a pressure (boost) operated switch, this should get you started:
http://content.honeywell.com/sensing.../catswitch.asp
Check out the "Low Pressure and Vacuum" link, and then go to the last page of the PDF file when it loads. It will show you the available vacuum operated switches, with part numbers.
