TC stall ? help!
Old Apr 11, 2011 | 03:56 PM
gallo-lo's Avatar
Default TC stall ? help!
im building a 5.3 stock bottom,317heads,z06cam,ls6intake,turbonetics t72/.96 t4,th400 ,gears low gear 3.00,or 3.42,3.55 with 27inch tall drag radial.i was thinkin of 80 lbs inj, my th400 is nice build 800hp max foot brake, i m in the market for TC,would im not sure what stall think of, 3400,3600, or 3800 im not looking to pass more than 6800RPM MAX.
Old Apr 11, 2011 | 07:57 PM
gallo-lo's Avatar
any1?
Old Apr 11, 2011 | 08:00 PM
rotary1307cc's Avatar
Just visit with a sponsor and they will set you up with what you need
I went with a PTC and it came setup perfectly the first time
Old Apr 12, 2011 | 06:31 AM
skinnies's Avatar
PTC is who I recommend, even with some 3.00 gears you should be able to go 1.4x 60ft's with the right converter on a radial.
Old Apr 12, 2011 | 07:39 AM
yep, i went with them because of you and couldn't be happier!
