timing chain
Old Apr 14, 2011 | 07:33 PM
lbm13186's Avatar
Default timing chain
so im building a new 6.0 block motor for fi and im putting all forged internals and im trying to keep the price down on my project and the company that im getting to do the motor suggested that i should just go with a stock type roller chain for like $70 and the double roller would be around $240, i plan on running around 8lb of boost for now and prob going to 14 to 18 down the road after i brake the new motor in.
So the question is, is it that much more important to go with a double over a single?
thanks
Old Apr 14, 2011 | 08:39 PM
XtremeDime's Avatar
Ive heard of people runnin the ls2 chain with no issues. I got ahold of a cheap, never used double so thats what Ive been using.
Old Apr 16, 2011 | 09:35 AM
camarols1's Avatar
The timing chain has no idea how much boost or HP you are making.
There's a bunch running a stock LS2 chain with great reliability.
I run the C5R chain from Katech and stock sprockets and I'm not worried one bit.
The best friend of any chain is a full size harmonic balancer. The bulk of timing chain failures are a result of using an underdrive pulley which lets engine harmonics get out of hand and revealing any weak links (pun intended) in the system.
Jim
Old Apr 17, 2011 | 12:10 PM
lbm13186's Avatar
thanks guys im going to go with a ls2 chain
but i was wondering what harmonic balancer do you think i should go with and what size??
